Access Event messages say, "Access Mode Normal"
  • Access Event messages say, "Access Mode Normal"
  • ScottLeedberg
    ScottLeedberg
‎2018-09-06 03:01 PM
Access Event messages say, "Access Mode Normal." What does this mean?
This is generally seen after you see either "Access Mode No Database" or "Access Mode No Communications" messages and the problem has been corrected.
This means the system is running Normally again.
Note: When in Normal mode, personnel records will be validated based on how the door is configured to validate while in Normal mode .
  • 2458
