Accepted Coding of Fractions and Decimals in Menta Expression Blocks
  • Accepted Coding of Fractions and Decimals in Menta Expression Blocks
  • Sacco
    Sacco
‎2018-09-06 11:10 AM
Menta will not accept the format of a decimal fraction without a zero preceding the decimal point.
Menta
Menta will only accept a fraction that contains a zero before the decimal point. For example, 0.1 is acceptable while .1 is not.
Menta will reject any fraction without a leading 0 in front of the decimal for any fraction, alternatively use a division operator.
For example, 1/2 is the same as 0.5, 2/5 is the same as 0.4.
  • 11013
