AS reboots when opening a Function block program in webstation
  • AS reboots when opening a Function block program in webstation
  • sesa115924
    sesa115924
  • sesa150555
    sesa150555
‎2018-09-06 09:48 AM
AS 1.4.1
Webstation
There is a issue in the AS that causes it to reboot when you view a Function Block program from webstation
There is a Hotfix that solves this issue. Contact Product support to get it. Please ask for hotfix 1.4.1.4302, this hotfix is for the specific problem.
Tags (3)
  • 15209
  • automation
  • server
