AS firmware upgrade to version 1.2 or 1.3 fails
  • AS firmware upgrade to version 1.2 or 1.3 fails
  • sesa119747
    sesa119747
  • HenrikTarpgaard
    HenrikTarpgaard
‎2018-09-11 09:56 AM
  • Upgrading the Automation Server firmware from version 1.0 to 1.2 or 1.3 fails
  • Upgrading the Automation Server firmware from version 1.1 to 1.3 fails
  • AS is going into failsafe when attempting to upgrade it to version 1.2
  • StruxureWare Building Operation 1.2 and 1.3
  • AS-L
  • AS-B
It is not possible to upgrade an AS more than one version at a time.
Upgrading from 1.0 to 1.3 should be done as follows::
  1. Install Device Administrator version 1.1 (if not already done) and upgrade the AS to firmware version 1.1
  2. After the upgrade has finished and the AS is ready, upgrade to version 1.2 from Device Administrator version 1.2
  3. When the AS is ready again, upgrade to version 1.3 from Device Administrator version 1.3
  • 11726
