AS-P default gateway changed when connected to an Advanced Display v3 (ADv3) Kiosk
  • AS-P default gateway changed when connected to an Advanced Display v3 (ADv3) Kiosk
  • StephenYang
    StephenYang
Admiral StephenYang Admiral
‎2023-06-01 05:48 AM
on ‎2023-06-01 05:48 AM
When DHCP network configuration is Enabled, the gateway changes when connected to an ADv3 through a Y-Cable. If other applications or devices need to route to the AS-P through the Gateway, the change of gateway will break the connection.
Advanced Display v3
AS-P overwrites its Default Gateway when connected to an ADv3
Update the Address Method to Static then enter the IP and Subnet address manually.
