AMT not showing First Name and Last Name information in the Transactions Window
  • AMT not showing First Name and Last Name information in the Transactions Window
  • sesa139513
    sesa139513
‎2018-09-06 02:27 PM
I/NET running in a Windows Environment
Xenta Server 527 / 731
The Host PC is not listed as the SQL Host Number in the Xenta 527 / 731.
In the configuration of the Xenta Router the Host PC has the default value of Zero.
To fix this you must:
  1. Connect the Xenta 731/ 527 Server 24 VAC power. Refer to the TAC Xenta 527 Installation Instructions (0FL-3956).
  2. Connect a PC to the Xenta Serves. Attach a serial cable from the computer’s COM port to the RS-232 B port on the front of the Xenta Servers. Refer to TAC Xenta 511/527/911/913 Handbook (0-004-7870) for complete instructions.
  3. Set the Xenta Server communication parameters. Start a Hyper Terminal Session on your PC, once the cable is connected it will display the default information on the Xenta. Note: The factory default login/password is root/root,
  4. Hyperterminal into the Xenta and login with appropriate credentials.
  5. From the dsh/> prompt type inethost
  6. Hit the ENTER key sixteen times to get to the SQL Host Number. It’s default is 0 and should be changed to the HOST NUMBER for the Host PC.
  7. The host PC number can be found in the I/O Server at the top right hand side in the TCP/IP setting box.
  8. Log out and be sure to restart the Xenta Server for settings to change.
  • TAC INET
  • 3918
