ADAA problems: can not dial in or out of the site
  • ADAA problems: can not dial in or out of the site
‎2018-09-06 03:25 PM
A PCU is set up as a 06 TAP. The RX and TX LEDs are flashing on the RS-232 card. A CBL048 cable is connected from the RS-232 card to the modem. The RD and SD lights are flashing.
ADAA
The wrong BIN file is in the PCU.
You have the wrong BIN file in the PCU. If the PCU is at the “Boot State”, you may have the wrong EPROM too. Install the correct BIN file; and it is strongly recommend to put in a compatible Asynchronous EPROM.
  • TAC INET
  • 1117
