A newly created lookup table for a Sigma Analogue Output (AO) object was designed to provide output in 10% increments. However, the object continues to display values in 1% steps.
Satchwell BAS & SigmaEnvironment
Sigma Controller (All Versions)
The AO object uses its value as the input to the lookup table. The output from the lookup table is then passed to the Digital-to-Analog (D/A) converter, which drives the physical output. However, the Sigma front end displays the AO object’s input value—not the processed output from the lookup table—resulting in the appearance of 1% steps.
To display the processed output value (i.e., the result of the lookup table) on the Sigma front end, a programmable object must be used. This object will apply the lookup table to the input value and then reference a standard AO object for output.
Example of a Programmable Object Configuration
10 XFLO = POINT 0|51
20 YFLO = LOOKUP (1812, XFLO)
30 RETURN VIA TEXT 92 VALUE YFLOPOINT 0|51: The control/input object1812: The lookup table numberYFLO: The processed output value to be displayed
Verification
To confirm the output value:
- Use a multimeter connected to the physical output of the AO object.
- Ensure the programmable object is correctly configured to reflect the desired output steps.
