A new MicroNet VAV controller has been installed under a MicroNet Microsmart Integrator (MN-MSI). How is real-time data obtained from and how are commands sent to the new VAV con...
  • A new MicroNet VAV controller has been installed under a MicroNet Microsmart Integrator (MN-MSI). How is real-time data obtai...
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-10 03:27 AM
A new MicroNet VAV controller has been installed under a MicroNet Microsmart Integrator (MN-MSI).  How is real-time data obtained from and how are commands sent to the new VAV controller?
MN-FLO3x
MN-MSI
DMS-35, -350A, -3500
The MN-MSI is an obsolete product and no documentation is available for it.
To integrate the new MicroNet VAV controller with a MN-MSI, create a Mode Control point Type 26 in the MN-MSI using the programming tool called DMS Operator Interface (also called PS-OPRIF or just OPRIF).
Use this file to learn and program the Type 26 Mode Control point.  It is a complete chapter from the MN-MSI documentation.
  • TAC IA Series
  • 6283
