A door DO is defined in the Resident I/O editor, but does not show up in the doors editor.
  • A door DO is defined in the Resident I/O editor, but does not show up in the doors editor.
‎2018-09-06 03:30 PM
  • I/NET Resident I/O editor
  • I/NET Doors Editor
 One of the causes is the doors are not saved in the NETCON file.
  1. Select Edit>Host Computer>Network Configuration
  2. Save any links with a "+" sign
  3. Select the link that contains the door and click Penetrate
  4. Save any controllers with "+" sign
  5. Select the controller that contains the door and click Penetrate
  6. Save any sub-Lan controllers with "+" sign
  7. Select the sub-Lan controller that contains the door and click Penetrate
  8. The door should have a "+" sign next to it.
  9. Click Save All
  10. Close out of the Network Configuration Windows
  11. The door should now show up in the door editor.
  • TAC INET
  • 920
