A BACnet/MSTP network will run longer than 4000 feet. Can the ASD or MicroSmart repeater be used?
  • A BACnet/MSTP network will run longer than 4000 feet. Can the ASD or MicroSmart repeater be used?
  • sesa119747
    sesa119747
  • SESA113595
    SESA113595
‎2018-09-06 02:57 PM
  • ASD repeater
  • MicroSmart repeater
  • BACnet/MSTP network
ASD or MicroSmart repeater won't extend communication distances on a BACnet/MSTP.
Both repeaters were tested and neither worked on a MSTP network.
  • TAC IA Series
  • 2672
