A 0xc000007b Error Occurs When Starting Workstation
  • A 0xc000007b Error Occurs When Starting Workstation
  • Zhenting_HU
    Zhenting_HU
‎2018-09-06 01:12 PM
After installing Vista successfully, Vista Server starts, but an error message occurs when starting Vista Workstation:
Application Error: The application failed to initialize properly (0xc000007b). Click on OK to terminate the application.
  • Vista Workstation
  • Windows XP Professional (tested with)
Some other software or driver installed on the computer caused Microsoft .NET Framework error.
  1. Download an IExpress setup file named dotnetfx from Microsoft website and install the file.
  2. Restart the computer and reinstall TAC Vista Server and Workstation, the issue should be solved.
  • 6348
