901 modem is dialing multiple times before successfully registering a change on the alarm window.
  • 901 modem is dialing multiple times before successfully registering a change on the alarm window.
‎2018-09-06 03:20 PM
The 901 modem is dialing multiple times (6-8) before successfully registering a change on the alarm window.
901 Modem
Normally it only takes one dial-up attempt to establish the communication link. If it takes 6-8 times, it indicates modem or telephone line problems.
In the dial-up parameters, define the number of dial up attempts before line block. 10 is the default value.
  • 1398
