78040/50/60 TAPs should not be mixed with 78041/51/61 TAPs
  • 78040/50/60 TAPs should not be mixed with 78041/51/61 TAPs
‎2018-09-06 03:44 PM
Last Updated: Administrator DavidFisher Administrator ‎2020-08-20 10:49 AM
Can 78040/50/60 TAPs be mixed in a network configuration with 78041/51/61 TAPs?
TAC INET
  • 78040 TAP
  • 78050 TAP
  • 78060 TAP
  • 78041 TAP
  • 78051 TAP
  • 78061 TAP
Mixing these two types has never been tested nor supported.
Never mix these two types of TAPs in a single network. Refer to Tech Tip 047 for more information.
  • TAC INET
  • 1091
