7716 P8UI4AO Expansion Board Types
  • 7716 P8UI4AO Expansion Board Types
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 03:30 PM
Need to distinguish between 0-10 V output and 4-20 mA output types
7716
Several options are available for use as the 7716 expansion board.
P8UI4AOC is the 4-20 mA output board and can be identified by the part number listed on the boards label. PN 330400-01A
P8UI4AOV is the 0-10 V output board and can be identified by the part number listed on the boards label. PN 330400-03
Here is a list of all 7716 boards and their part numbers
Here is a picture of P8UI4AOV  0-10 V output board with the PN 330400-03 shown.
  • TAC INET
  • 7624
