32-bit Modbus write values are not writing correctly
  • 32-bit Modbus write values are not writing correctly
  • sesa139513
    sesa139513
  • Dave_Shore
    Dave_Shore
  • DavidChild
    DavidChild
‎2018-09-11 04:37 AM
When a modbus AO is created and set to 32-bit real swapped, the correct value is not seen at the modbus device.
  • 1000 is written and 1000 is shown correctly at the Modbus device.
  • 1001, 1002, 1003 are written but 1000 is seen at the Modbus device.
  • 1004 is written and 1004 shows correctly at the Modbus device.
  • And so forth. The larger the number, the larger the error increase.
  • Enterprise Server (ES)
  • Automation Server (AS)
When 32 bit real swapped is selected
Further down the configuration page, the write function code defaults to "06". 06 is to set a single 16-bit register write and this needs to be changed.
Use the drop down tab and set the function code to "16". 16 is to preset multiple registers i.e. 2 off consecutive 16-bit registers or a 32-bit register.
Tags (6)
  • 13950
  • 48
  • 64
  • all
  • fc16
  • setting
100% helpful (2/2)
