3 State Event Sequence to control certain Access Control Doors
  • 3 State Event Sequence to control certain Access Control Doors
  • sesa139513
    sesa139513
  • Tom_Poovey
    Tom_Poovey
‎2018-09-06 02:46 PM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-28 11:34 AM
TAC INET
I/NET site
Three State control requirement
When using the Door Points ("08" & "09") with event sequences, the following actions will occur:
  • A “Start” command is equal to the “Secure Mode” of the door
  • A “Stop” command is equal to the “Unlock Mode” of the door
  • A “Lock Door” command is equal to the “Lock Mode” of the door
  • TAC INET
  • 3143
