102-AX Plug-In values described
  • 102-AX Plug-In values described
  • Sacco
    Sacco
‎2018-09-11 01:56 PM
Description of the Parameters used in the 102-AX Plug-In
EcoStruxure Building Operation, TAC Vista
  • LonMaker
  • NL220
  • HTML 102-AX Plug-In
This may aid in finding the SNVT associated with each Plug-In field.
Status Parameters
nviBoxFlow
nvoActualValue
nviAplicMode
nviOccCmd
nviEmergCmd
nvoLocalLatch
INPUT OBJECTS
nvoUnvInput1
nvoEmergCmd
nvoAuxTemp1
nvoUnvInput2
nvoLocalOccLatch
nvoUnvInput3
nvoCO2ensor
nvoAuxTemp2
nvoUnvInput4
nvoSetPtOffset
VAV STATUS
nvoOccpncyStatus
nvoUnitStatusMode
nviTerminalLoad
nvoSpaceTemp
nvoEffectSetPt
nvoBoxFlow
nvoFlowControlPt
nvoAirPressure
nvoHighSpaceTemp
nvoLowStaticPress
nvoLowStaticPress
nvoOAirFlowRatio
NETWORK BOUND INPUTS
nviApplicMode
nviOccCmd
nviEmergCmd
nviAirFlowReset
nviCO2
nviDuctInTemp
nviOutsideTemp
nviRelStPt
nviUnvOutput1
nviUnvOutput2
nviUnvOutput3
  Operating Parameters
UCPTcooling Band
SCPTsetPnts.unoccupied_cool
SCPTsetPnts.Standby_cool
SCPTsetPnts.occupied_cool
UCPTheatingBand
SCPTsetPnts.unoccupied_heat
SCPTsetPnts.Standby_heat
SCPTsetPnts.occupied_heat
UCPTovrdDuration
SCPTmaxRange
UCPTresponseRate
nviSetPoint
nciVAVSelctnCntl.oP.ESS (UCPTvavSelection
UCPTnormalPeriod.minute
UCPTnormalOpen
Airflow Parameters
Airflow Setpoint
SCPTminFlow
SCPTmaxFlow
SCPTminFlowStby
UCPTunocAirFlow
SCPTminFlowHeat
UCPTminFlowWU
UCPTmaxFlowWU
UCPTfanOnFlow
UCPTfanOffFlow
Airflow Reset
nviAirFlowReset
UCPTco2LoReset
UCPTco2HiReset
Outside Air Requirement
UCPToccOAReqd
UCPTunocOAReqd
nvoOAirRatio
Airflow Setting
SCPTgain
UCPToffsetPress
UCPTpressCutOff
UCPTairFlowCoeff
UCPTloStatPrior
Unit Parameters
Hardware Configuration
I/Stat Configuration
Node Configuration
Calibration
Labels (2)
  • 16875
100% helpful (1/1)
