012 NPR's Broadcast UDP/IP packets are not utilized by the control network applications
  • 012 NPR's Broadcast UDP/IP packets are not utilized by the control network applications
‎2018-09-06 03:27 PM
Are the 012 NPR’s Broadcast UDP/IP packets utilized by the control network applications?
012 NPR
The only Ethernet broadcasts that will be used are standard ARP broadcasts for normal MAC to IP address resolution. The NPR requires a static IP address assignment.
No. The Broadcast UDP/IP packets are NOT utilized by the control network applications.
  • TAC INET
  • 1050
