altistart via ltmr Ethernet IP
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
Send InviteCancel
Posted: 2024-04-2303:25 PM
I have connected the LTMR via ethernet IP and set up the Generic Ethernet module as shown in the manual. input Assembly instance 116 size 64 com format int....... so where on earth is a list of the names of these tags????? the manual does not explain this!!! "LTMR:I.Data[0]" What address is this pointed to in the LTMR?
