Tridium niagara Jace 8000 not pinging
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Tridium niagara Jace 8000 not pinging
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
menda
menda
Cadet
Posted: ‎2024-02-22 09:24 AM
Hi ,
After commissioning completed Jace is not communicated and check in putty tool i'm getting this error. i tried my best to resolve this issue but I'm unable to resolve this issue. Pls give me some solution for this issue.
continuing boot...
Applying file permissions...
starting WDT reset utility...
launching qspyd2...
Release phy reset lines...
if_up: retries exhausted
NOTICE: en0 adapter initialization failed, skipping configuration
route: writing to routing socket: Network is unreachable
**WIFI is disabled**
----------------------TCP/IP Network Status------------------------------
WARNING: Failed to get valid IPv4 address of adapter dm0, can't add IP multicast route.
pf enabled
calling bnbpf with dm
Starting BACnet resource manager
Unable to access /dev/bn-dm0
Failed starting BACnet resource manager on dm0
Unable to access /dev/bn-dm1
Failed starting BACnet resource manager on dm1
Starting SRAM SPI driver
SRAM mounted successfully at /dev/chunkfs
pps: NOTICE: PPS initializing
pps: NOTICE: PPS attaching /pps
pps: NOTICE: PPS attached /pps major 2 minor 6
Starting USB-0 and USB-1 Host controllers...
Started USB-0 and USB-1 Host controllers
get_ctrlperms: ctrlperms set to 644
Check for usb firmware updates
bus 0,dev 2:OK 07004081J6WWS22 Tridium485-2_r12.bin
Check for usb firmware updates done
Starting /dev/serusb1 on busno=0, devno=2...
Starting /dev/serusb2 on busno=0, devno=2...
starting backup/shutdown monitor
INFO    [2024-02-17 14:20:23][nverify] Verifying archive /opt/niagara/bin
INFO    [2024-02-17 14:20:29][nverify] Verifying archive /opt/niagara/jre
niagarad_init: Integrity validation success. Continuing niagarad startup.
niagarad_init: creating mqueue /niagarad-to-os
niagarad_init: creating mqueue /os-to-niagarad
login:
  • @tridium
Replies 0
