TM221 PLC - How to use the internal clcock
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • TM221 PLC - How to use the internal clcock
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
JCardoso
JCardoso
Cadet
Posted: ‎2022-12-28 01:44 AM
1531
God Morning,
I am an individual professional, with a degree in electronic engineering. I'm doing an automation project for an industrial equipment. I need to use the internal clock of the TM221C24R PLC so that the program decides if the system was turned off due to a power cut in the network or if it was intentionally turned off by the operator.
I was thinking about setting a minimum time for a power cut of 3 minutes. If the cut is longer than 3 minutes, it would be an intentional cut by the operator.
How can I invoke the hh:mm built-in variables to establish an IF-Then-Else condition?
Someone can help me?
José Cardoso
Replies 4
VARFIC
Ensign VARFIC
Ensign
Posted: ‎2022-12-28 08:48 AM
1518
Hi.
Try check the variable of system like %SW.
There are some options to help in your issue
JCardoso
JCardoso
Cadet
Posted: ‎2022-12-29 01:26 AM
In response to VARFIC
1503
Hello VARFIC.
I tried before that Sistem Word, but I can´t reed or store that word anyware, to use it to compare the new S13 value in the next scan of the controler. I'm hardworking to chose a way to make it work, but till now with no success.
Anyway I thank you very mutch by trying help me.
VARFIC
Ensign VARFIC
Ensign
Posted: ‎2023-01-02 02:38 PM
In response to JCardoso
1475
Hi JCardoso
Try analyse the system word from %SW48 to %SW58.
To store de variables you need choose the retain variable on configuration.
Regards
JCardoso
JCardoso
Cadet
Posted: ‎2023-01-02 03:12 PM
Hi VARFIC
I will try your suggestion. It seems that will solve my problem. I had forgotten the retain variables.
As soon as I get a solution, I'll let you know.
Thank you very much.
