Star Delta with ATS22
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
Send InviteCancel
Posted: 2024-03-1806:38 PM
I have some 180HP 440V 1200@rpm motors coupled to compressors, variable load, using ATS22 , so i get a 375 amp starting peak current, also if ATS fails i have a Star Delta starting conection on parallel with 625 amp starting peak, i wanna know if i could mix both, use the ATS22 for star starting and when is allready runing change to Delta. to decrece the starting current.
