Hi all,
I am new to Schneider products and building automation as a whole. I was using the SpaceLynk LSS100200 to test and connect a thermostat. Although it was working fine before, I am now unable to connect to the SpaceLynk. The 1st LED status indicator is blinking green but the second one remains off after connecting the power supply.
I would greatly appreciate any input on how to fix the problem or if there is anything else I'm missing. Thanks in advance.
Hi Ahmed,
The solution I found was to re-flash the SD Card for the SpaceLYnk with the corresponding firmware.
I followed some application notes on the site some time ago. I'll include some relevant links (community posts and application notes) that I've dug up but not sure if these were the exact ones I followed.
SpaceLynk Lss100200 - Failure at startup
https://community.se.com/t5/SpaceLogic-KNX-Forum/SpaceLynk-Lss100200-Failure-at-startup/m-p/408248
AN050 - How to flash microSD card in spaceLYnk
https://community.se.com/t5/SpaceLogic-KNX-Forum/AN050-How-to-flash-microSD-card-in-spaceLYnk/m-p/14...
How to flash microSD card in Wiser for KNX and SpaceLynk
https://www.se.com/hk/en/download/document/AN2_001/
Edit: I've found the exact pdf I followed some time back and also attached it for your reference. Just make sure to check your firmware version.
Hope this helps!
Please if you found a solution for this problem..tell me
Hi Ahmed,
Hope this helps!
