Semi-flush meter main combo installed surface mount
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
Send InviteCancel
Posted: 2023-01-2510:15 AM
We have a SC1624M125F all in one semi-flush meter main combo. We need to know if that can be installed surface mount? The panel looks like a surface mount panel just with the side and top tabs connected to it so it seems like it should be ok. If it's not approved, what is the difference between the two panels other than the side and top tabs that would make it not approved to be mounted surface mount?
