Saving memory word value once
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Saving memory word value once
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
jmilliaan
jmilliaan
Cadet
Posted: ‎2022-06-29 12:32 AM
1677
I have a simple counter that counts up every 1 second using a timer. How do I save the value of the counter when a button is pressed? I have tried this by assigning a new memory word value to be the same as the counter value. But because the counter always counts up every second, the memory word also changes every second. How can I save it only when the button is pressed, and it maintains its value.
VARFIC
Ensign VARFIC
Ensign
Posted: ‎2022-06-29 03:33 AM
1652
it is possible you provide a example or code you are working?
Before could you try using a public variable in your program?
Regards
VARFIC
Ensign VARFIC
Ensign
1653
Regards
jmilliaan
jmilliaan
Cadet
Posted: ‎2022-07-04 01:55 AM
In response to VARFIC
I'm trying to make a stopwatch program using ladder logic. I haven't figured out how to make the "lap" function found in stopwatches. Attached is my LD program, I use a timer that pulses every 1ms with preset 1000. The timer output is then connected to a the CU of a counter with preset 60 (indicating 1 minute). The preset reached of said counter is then connected to the CU of another counter with preset 60 (indicating 1 hour).
I want to save the values of each counter when the lap button is pressed.
