We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
STR-150 & Return Sensor with Xenta 122-FC
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • STR-150 & Return Sensor with Xenta 122-FC
  • Subscribe to RSS Feed
CraigEl
Administrator CraigEl Administrator
33
MikaelKrantz
Kirk MikaelKrantz Kirk
7
Omaelk
Janeway Omaelk
3
chris_clerc
Administrator chris_clerc Administrator
2
Back to Ask the Community
digvijay
Lieutenant JG digvijay
Lieutenant JG
Posted: ‎2019-09-09 11:31 PM . Last Modified: ‎2020-12-02 04:31 AM
7
3894
Hi All,
I have a scenario in which an STR-150 thermostat and a return sensor are to be connected to a Xenta-122FC. I need to run the Xenta controller based on the return sensor temperature value and setpoint to be given from server. And have to export the temperature & setpoint values from STR-150 to other controller(to be used for other purpose). Does anyone know how to achieve this? Which of the Xenta terminals the thermostat and return sensor should be connected? How should be the bindings be done?
  • 122FC
  • STR150
  • xenta
Replies 7
Omaelk
Janeway Omaelk
Janeway
Posted: ‎2019-09-10 04:46 AM
Hello @digvijay , welcome on Exchange community. I add @MikaelKrantz to the thread as he may be able to help you with your issue.
PS: do not hesitate to use the search bar with key words to check if your issue was not already discussed somewhere in the community 😉
MikaelKrantz
Kirk
Posted: ‎2019-09-10 06:58 AM
5
3882
The TAC Xenta 122-FC device has to be configured with the ZBuilder tool, that is an LNS PlugIn software.
Here you can select what input you should use for the temp, and under Configuration tab, Application, Special Functions, there is a checkbox for selecting Do not use space temperature from STR150.
digvijay
Lieutenant JG
Posted: ‎2019-09-10 07:24 AM
In response to MikaelKrantz
2
3876
Thanks Mikael! How can I export the STR-150 Temperature and Setpoint values in this situation?
MikaelKrantz
Kirk
Posted: ‎2019-09-10 07:36 AM
In response to digvijay
1
3872
Not from the sensor, but from the controller.
nvoSpaceTemp
nvoEffectSetpt
digvijay
Lieutenant JG
Posted: ‎2019-09-11 10:33 PM
Let me check on the site for the values on these NVOs and get back to you. Thanks!
Waqas_Shahid
Ensign Waqas_Shahid
Ensign
Posted: ‎2025-05-26 12:06 AM
142
Is there any option for the selection of either STR-150 or temperature sensor once controller is added under SBO under these sub folder as my previous selection in this controller on return sensor now I want to replace it with STR-150 and I don't have LNS or Tac vista.
MikaelKrantz
Kirk
Posted: ‎2025-05-26 12:53 AM
In response to Waqas_Shahid
What type of controller du you have?
STR150 only talk to the TAC Xenta 100 series.
Or, do you think about STR350, which are using SNVT?
This is a heading
