Restraint current Micom p545
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Restraint current Micom p545
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
Layla
Layla
Cadet
Posted: ‎2025-03-03 04:35 AM
668
I have a question regarding the Micom P545 line differential protection. I understand that the bias current is calculated as the scalar sum of the currents at both ends, divided by 2. However, when viewing the bias current in the protection settings, specifically in the Measurement 3 section, it shows double the value I expect. I am uncertain whether the protection has a specific configuration that alters the calculation method, or if I have misinterpreted the formula. I have attached example values collected from the protection for reference.
Gregory_Meunier
Lt. Commander Gregory_Meunier Lt. Commander
Lt. Commander
Posted: ‎2025-03-03 02:31 PM
Hi Layla,
To answer your question, we need the setting files of the two relays.
We recommend that you do not share them here.
Please contact your local technical support so we can provide a dedicated answer to your issue.
https://www.se.com/ww/en/work/support/country-selector/contact-us.jsp
Gregory_Meunier
Lt. Commander
Hi Layla,
