Neutral Voltage
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
Send InviteCancel
Posted: 2022-11-2212:53 AM
Neutral Voltage
Greetings,
I had 36V between Neutrl and Earth(PE) on a TT Earthing System. My rectifier Modules started popping 1 by 1 until the cause of the elevated neutral voltage was removed. This is 3 Phase with Neutral Earthed at the Source. Why do modules burn and how do i go about to eliminate this? Will an RCD Work?
