Netbotz 755 Camera Feed to External Software
  • Netbotz 755 Camera Feed to External Software
129
72
AndyGoodall
AndyGoodall
Cadet
Posted: ‎2024-03-20 04:57 AM
896
Hi guys
I recenelty replaced my old Netbotz 320 with a Netbotz 755. With our old device we were able to pass the video feed through to our iSpy cctv viewing software, does anyone know if the 755 can do the same? I have tried every combination I can think of, even just having the webpage pass through but even that fails at the first page due to a certificate error.
Tearing my hair out with this one, any help appriciated
Admiral
Posted: ‎2024-09-26 12:06 PM
Hello @AndyGoodall,
I am unsure on how to specifically integrate with iSpy part as I only have experience with NetBotz and Data Center Expert.  However, the only way to integrate images from the NetBotz appliance is through the RestAPI.
Once logged into the NetBotz 755 web interface, navigate to https://IPADDRESS/docs/rest/
Let's start by polling the camera ID so that we can then poll images.  Expand the assets heading and then the first option for GET /assets.  Scroll down to the fields and for types enter CAMERA
Click Try it out! Scroll down a little bit and you should have a Response Body that contains a list of your cameras, each with an "id".  Grab one or multiple of the ids.
There are a few related calls that you could use, the most common if you are looking to get images from the live feed:
Both of those call just require the camera ID to retrieve an image.  I'm unsure if iSpy can integrate with cameras using RestAPIs, but it is the available option on the NetBotz 750 series.
Kind Regards,
Cory
Admiral
Hello @AndyGoodall,
Kind Regards,
Cory
