M25I PLC IP Addresses:- Ethernet 1 & Ethernet 2
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • M25I PLC IP Addresses:- Ethernet 1 & Ethernet 2
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
Mtoto
Ensign Mtoto
Ensign
Posted: ‎2022-07-21 03:37 AM
1378
Hi Support,
Refer to the above subject, after configuration of M251 PLC
>> Ethernet port 1 to 192.168.0.248\ Subnet 255.255.255.0 (Communicating with the HMI, PLC configured as slave devices )
>> Ethernet port 2 to 192.168.0.249\ Subnet 255.255.255.0 ( PLC configured as slave devices to be  configured as master to communicate with Tank gauge system ATG)
When built and compile the program its generate an error " IP addresses must not be in the  same subnet"
Existing devices IPs are of the range 192.168.0.x
Please assist.
Posted: ‎2022-07-21 03:52 AM
1369
ethernet 1 and ethernet 2 should be in two different network for example
-eth1 - 192.168.0...
-eth2 - 192.168.1....
If PLC is slave device then eth1 is using for communication with HMI IP:192.168.1...
and eth2 as slave device 192.168.0...
best regards
Mtoto
Ensign Mtoto
Ensign
Posted: ‎2022-07-21 04:07 AM
In response to Anonymous user
Hi Crewman
thankyou,
Regards
idris
