Looking for a product/help to solve an engineering requirement
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Looking for a product/help to solve an engineering requirement
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
Posted: ‎2021-06-16 04:33 AM
2075
Hi experts!
I am looking for a cost effective solution to an engineering requirement.
That is to provide a constant (vertical) tension in a cable, preset to be from 100N to 2000N, with a speed of up to 500mm/s, for a stroke of approximately 500mm. I was thinking linear cylinder with a strain gauge for feedback and control. High precision is not necessary.
To explain further - a cable is pulled and movement resisted until the pre-set tension is reached, then movement commences and speed adjusts in real time to keep the same tension (+- say 2%). Tension is maintained in both directions (i.e. if cable slackens, movement reverses to maintain tension).
Anyone who can supply a solution or comment, much appreciated!
  • actuator
  • expert
  • mechatronics
  • solution
Posted: ‎2021-06-21 09:01 PM
In response to Jean_Commeignes
thanks for the comment, but I am looking for an electric cylinder, which I thought Schneider provided, but have since found what I need at another supplier.
Neurosteel
Jean_Commeignes
Administrator Jean_Commeignes Administrator
Posted: ‎2021-06-17 08:34 AM
2057
Hello Neurosteel,
Exchange Community Domains are splitted between mainly:
  • Power Distribution
  • Building Automation
  • Industrial Automation
Your question seems purely mechanical, doesn't it?.
If this is right, Exchange Community won't be able to address it.
Best regards
Jean COMMEIGNES
Schneider Electric Community Manager for Power & Building
Neurosteel
