LSS100200 404 Not Found message
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • LSS100200 404 Not Found message
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
Istvan5
Crewman Istvan5
Crewman
Posted: ‎2023-05-11 01:28 AM
1417
can someone help me,where can I download a recovery file for HW3.1?After HW reset, the device sends a 404 Not Found message to the address 192.168.0.10.
Thanks.
Istvan5
Crewman Istvan5
Crewman
Posted: ‎2023-05-19 02:15 PM
1315
Hello everyone reading this post.
I found the "recovery" file,but it didn't help my problem so far.
Can be found here: https://www.se.com/hk/en/download/document/AN2_001_SL/
Thanks.
Istvan5
Crewman Istvan5
Crewman
1316
Thanks.
Istvan5
Crewman Istvan5
Crewman
Posted: ‎2023-05-20 05:24 AM
In response to Istvan5
Hi everybody,
A result was achieved.
The original problem- Everything works except:  Configurator/System-404 Not Found
After HW reset (2X10 seconds with reset button)- to 192.168.0.10 user:admin,password:admin-404 Not found. The device was thus unusable.
With original SD card: LED1 (CPU) flashes, LED2 (operation) lights up green, and the aforementioned phenomenon.
With a new SD card appropriate "recovery" file (spacelynk/HW3) with unzip: LED1 is flashing, LED2 is dark. So it recognizes it, but it's useless.
Solution: With the original SD card after 2X10 second reset button (HW reset) I took the power off before booting. I replaced the SD cards,power on, and recognized it and requested the firmware update. Now it works perfectly.
I don't think this is the best solution, but this is the only one that worked for me. I hope someone finds this information useful.
