Is the a block in the ecostruxure control expert base library that is switching/ transfer block?
  • Industrial Automation
  • Is the a block in the ecostruxure control expert base library that is switching/ transfer block?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
brightonrust1
brightonrust1
Cadet
Posted: ‎2024-03-19 10:46 AM
623
I'm trying to switch between two real values based on a Boolean. 0 = Var1 (Real) and 1 = Var2 (Real). In many DCS platforms there is a block that allows you to do this and then you can have some adjustable filter time between the two values. If there is some block in Ecostruxure that can accomplish this I would love to use it.
Thanks so much,
Brighton
MatthewM
Lt. Commander MatthewM
Lt. Commander
Posted: ‎2024-09-24 09:28 PM
SEL selects either of two inputs based on 0 or 1 status of a bool.  Like an IF statement.  Any signal conditioning would have to be done before the select input.
