Hyperlink error "took too long to respond" via Panel in Webstation. On Workstation works perfect.
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Hyperlink error "took too long to respond" via Panel in Webstation. On Workstation works perfect.
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Kirk MikaelKrantz Kirk
7
Back to Ask the Community
MaximZagi
Crewman MaximZagi
Crewman
Posted: ‎2024-05-07 02:01 AM
1648
Hello everyone,
I have faced an issue with a hyperlink in a Webstation when I try to open it in a Panel in a popup screen.
When it's open via Workstation it's working perfectly fine.
Any suggestions regarding this issue?
Best regards,
Maxim
  • ecostruxure building operation
CraigEl
Posted: ‎2024-06-19 07:52 PM
@MaximZagi as I noted above, you will need to uncheck redirect web clients to HTTPS
Replies 5
CraigEl
Posted: ‎2024-05-07 04:25 PM
1614
@MaximZagi we probably need to understand what the hyperlink is trying to open. A copy of the graphic would be useful to understand the issue.
What version of EBO is this?
MaximZagi
Crewman MaximZagi
Crewman
Posted: ‎2024-05-07 10:59 PM
In response to CraigEl
Hi Craig,
Thanks for a quick response.
Hyperlink trying to open a simple address of Veropoint plc, for example 192.168.0.101.
Picture attached.
We are currently using EBO v 5.0.3.117.
CraigEl
Posted: ‎2024-05-08 02:16 AM
1582
@MaximZagi I notice that the site uses HTTP communication, if you have redirect web clients to HTTPS set it may cause issues with sites that don't support HTTPS
MaximZagi
Crewman MaximZagi
Crewman
Posted: ‎2024-06-19 03:44 AM
Hi Craig,
You correct as always.
To connect to the Webstation you need to access via HTTPS port and Veropoint site can support only HTTP connection.
Do you have something on your mind how we can get around this incapability?
CraigEl
