Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
Posted: 2020-07-28 09:33 PM . Last Modified: 2020-07-29 05:49 PM
(The page cannot be displayed on the website.)
Posted: 2020-08-13 05:54 PM . Last Modified: 2025-08-12 05:20 AM
I can't tell very much from a screen shot. But as a first step you should run the SBO Reports Agent Configuration Tool from the community.
If you don't have access to this then you should contact your local Schneider Electric team to request the correct access to the Community.
Posted: 2020-08-13 06:41 PM
It looks like a strange path, I'd expect to see backslash (\) characters in the path. It seems like it might be something strange due to Operating System language.
It may also be permissions are you installing as an Administrator?
I suggest that you contact your local Schneider Electric Support organization to get assistance.
Posted: 2020-07-28 09:48 PM . Last Modified: 2025-08-12 05:20 AM
I don't see any images!
However please start by letting us know how you have configured the system:
Are the ES and reports server on different computers or the same?
Did you run the reports preparation tool before installing reports?
What are the Operating systems and SQL versions?
I don't see that you have access to our forums, are you a Schneider Electric Partner? If you aren't then you should contact your local Schneider Electric technical support organization.
Posted: 2020-07-29 05:46 PM . Last Modified: 2020-07-29 06:08 PM
Re-use the ES and report servers on different computers?
Answer: ES Server and Report Server are the same PC.
Run the report preparation tool before installing the report.
answer:No
What is the Operational and SQL version?
Answer: The operating system is Windows 7 32 bit and the SQL version is 2012.
Posted: 2020-07-29 05:59 PM
Since you once again have refused to answer the question about you being a Schneider Electric Partner or an end user, I can only assume that you are not a a Schneider Electric Partner. You should contact your local Schneider Electric technical support organization for further assistance.
Posted: 2020-08-13 04:33 PM . Last Modified: 2020-08-13 05:29 PM
We are partners. I have the code,
Question: Please tell me why you are getting this error message
Posted: 2020-08-13 06:11 PM
Can I see why the error pops up when I install Enterprise Central
Posted: 2020-08-18 09:50 PM . Last Modified: 2020-08-18 10:02 PM
The report was installed while connecting the Internet LAN line and entering a static IP.
Question Are the reports and Internet static IPs related?
Posted: 2020-08-19 01:43 AM . Last Modified: 2022-10-19 02:10 AM
Version is 2.0
There is one Enterprise Server PC and one Report Server PC.
You have installed a web report server.
ink https://community.se.com/t5/Building-Automation-Knowledge/Unable-to-log-in-to-the-report-server-via-a-web-browser/ta-p/4288
Can I connect it as it hangs
Additional Questions Can the Enterprise be used with a 3-month license?
