Easergy PRO - Third party software components
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Easergy PRO - Third party software components
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
ControlSystemSoftware
Cadet
Posted: ‎2023-11-13 07:12 PM
1494
Easergy Pro makes use of third party software components of which some have existing security vulnerabilities. Winpcap is also not supported anymore.
Easergy Pro third party software Components with vulnerabilities / not supported for security patches:
Software component
Version
Release date
Latest version
Latest version release date
Notes
Security vulnerabilities
Winpcap driver
4.1.3
2013
4.1.3
2013
Industry recommendation is to migrate to a supported version of Npcap
[https://www.winpcap.org/]
 No patches or support provided
Apache log4net for .NET 4.5
2.0.8
2017
2.0.15
2022
Industry recommendation to migrate to supported version.
The installed version has a critical severity security vulnerability
[https://www.nuget.org/packages/log4net/2.0.8]
https://github.com/advisories/GHSA-2cwj-8chv-9pp9
https://nvd.nist.gov/vuln/detail/CVE-2018-1285
JSON.Net
12.0.3.23909
2019
13.0.3
2023
The installed version has a high severity security vulnerability
https://github.com/advisories/GHSA-5crp-9r3c-p9vr
SharpCompress
0.25.1
2020
0.34.1
2023
The installed version has a medium severity security vulnerability
[https://www.nuget.org/packages/SharpCompress/0.25.0]
https://github.com/advisories/GHSA-jp7f-grcv-6mjf
SSH.NET .NET4.0
2016.1.0
2017
2020.0.2
2020
[https://www.nuget.org/packages/SSH.NET/2016.1.0]
https://github.com/advisories/GHSA-72p8-v4hg-v45p
May I ask if it would be possible to confirm the following:
  1. Is Winpcap required or can the software be used for protection relay programming without Winpcap?
  2. Is it possible to use nPcap instead of Winpcap?
  3. Are there any plans to update Easergy Pro to use supported version of the above mentioned software components that have security vulnerabilities fixed? If so, would it be possible to share a target date?
Replies 5
CraigEl
Posted: ‎2023-11-14 10:55 PM
@ControlSystemSoftware I suggest that you contact your local Schneider Electric Customer Care center to get assistance with this query. It doesn't sound like something that should be discussed in a semi open forum such as this.
https://www.se.com/au/en/work/support/customer-care/contact-schneider-electric.jsp
CraigEl
Posted: ‎2023-11-14 11:10 PM
I see that you have made a request to Customer Care previously that seems to have been miss-assigned  by the system. I have hopefully added enough information to the case so that the correct team in Australia will pick it up and respond to you.
CraigEl
Posted: ‎2023-11-14 11:18 PM
Alternatively you may want to go to Cybersecurity support portal where you can find known vulnerabilities and mitigations, or report a vulnerability.
https://www.se.com/ww/en/work/support/cybersecurity/security-notifications.jsp
CraigEl
Posted: ‎2023-11-15 09:10 PM
@ControlSystemSoftware I took a look at your case in our Customer Care system and it seems to have gained some traction following my changes. It has progressed to the Expert Support team responsible for the product and hopefully you'll get an answer soon.
Cadet
Posted: ‎2023-11-23 12:38 AM
Thank you - much appreciated.
