EPO 2022 INVALID_CREDENTIALS even after follow configuration video.
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • EPO 2022 INVALID_CREDENTIALS even after follow configuration video.
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
AVEVA
AVEVA™ Plant SCADA
EcoStruxure™ Power Operation
Back to Ask the Community
Rvbatista
Ensign Rvbatista
Ensign
Posted: ‎2023-03-02 04:04 AM . Last Modified: ‎2023-03-02 04:07 AM
5454
Hello
I followed the steps in this video:
https://www.youtube.com/watch?v=PTHwubIbmxw&list=PLa7UGrWOTyjk8BofByrEfGbo43Fi_K2XE&index=43
but I'm continue getting the INVALID_CREDENTIALS error.
Rvbatista
Ensign Rvbatista
Ensign
Posted: ‎2023-03-21 01:16 AM
In response to ArtemP
4
5374
Hello ArtemP, thanks for your reply.
That video ist in this series.
I solved by installing the deployment server.
Replies 10
ArtemP
ArtemP
Cadet
Posted: ‎2023-03-20 11:44 PM
5378
The video seems pretty old. Try this series - https://www.youtube.com/watch?v=hBG9c829riM&list=PLa7UGrWOTyjk8BofByrEfGbo43Fi_K2XE&index=10&ab_chan...
It"s also better to switch off the Windows Firewall and antiviruses. or check which ports they block
Rvbatista
Ensign Rvbatista
Ensign
4
5375
Estevaos108
Estevaos108
Cadet
Posted: ‎2023-05-17 07:36 AM
In response to Rvbatista
5248
How and where I can install it? I'm trying to search for Deployment Server for PO, but I couldn't find anything related...
rogeriodelgado
Ensign rogeriodelgado
Ensign
Posted: ‎2023-05-17 08:10 AM
1
5239
Eu estou com o mesmo problema para ativar o WebHMI, assisti o vídeo mas não deu certo. Aparece INVALID_CREDENTIALS.
Pode me ajudar?
Rvbatista
Ensign Rvbatista
Ensign
Posted: ‎2023-05-17 12:13 PM
In response to Estevaos108
5228
Hello @Estevaos108 the deployment server is an option (checkbox) of the same installer that you used to install EPO.
Estevaos108
Estevaos108
Cadet
Posted: ‎2023-05-17 12:15 PM
5225
But my PO is already installed, I need to install it again or just modify?
Rvbatista
Ensign Rvbatista
Ensign
In response to rogeriodelgado
Olá @rogeriodelgado durante o processo de instalação do EPO tem um checkbox para marcar pedindo a instalação do deployment server. Fora esse detalhe é só seguir o vídeo do primeiro link.
Rvbatista
Ensign Rvbatista
Ensign
Posted: ‎2023-05-17 12:18 PM
I believe that you can use the modify to install the deployment server, otherwise you have do uninstall and install again.
naseer12off
Crewman naseer12off
Crewman
Posted: ‎2024-12-14 08:44 AM
2886
it's not working even after installing the deployment server.
andre.vargas
andre.vargas
Cadet
Posted: ‎2024-12-17 05:31 AM
In response to naseer12off
In my case I am using EPO 2022 in windows server 2022  and is not working, I folowed the steps from video and install deployment server, but nothing to work.
