Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
Posted: β2024-08-06 03:07 PM
Good morning everyone.
EBO Workstation 1.9.4.29 has started to crash frequently on one of our sites. This happens when working with the alarm console (expanding it, rearranging the order, etc.) and it appears to me to be an issue in the Xceed module, as every fault description includes references to that.
However I have not been able to work out exactly what is causing the issue. Has anyone else experienced this & can offer assistance?
Here's a sample error log:
Input string was not in a correct format.
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String, NumberStyles, NumberBuffer&, NumberFormatInfo, Boolean)
at System.Number.ParseInt64(String, NumberStyles, NumberFormatInfo)
at System.String.System.IConvertible.ToInt64(IFormatProvider)
at System.Convert.ToInt64(Object, IFormatProvider)
at SE.WorkStation.Otm.Globalization.GlobalizationValue.GetTypedEnumerationValue(Object)
at SE.WorkStation.Otm.Globalization.GlobalizationValue.GetEnumerationPresentationValue(Object)
at SE.WorkStation.Otm.Globalization.ValueValue.UpdatePresentationValue(Object)
at SE.WorkStation.Otm.Globalization.ValueValue.get_PresentationValue()
at SE.WorkStation.Alarms.Windows.Views.MonitoredValueConverter.Convert(Object[], Type, Object, CultureInfo)
at System.Windows.Data.MultiBindingExpression.TransferValue()
at System.Windows.Data.MultiBindingExpression.Transfer()
at System.Windows.Data.MultiBindingExpression.HandlePropertyInvalidation(DependencyObject, DependencyPropertyChangedEventArgs)
at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject, DependencyPropertyChangedEventArgs)
at System.Windows.DependentList.InvalidateDependents(DependencyObject, DependencyPropertyChangedEventArgs)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex, DependencyProperty, PropertyMetadata, EffectiveValueEntry, EffectiveValueEntry&, Boolean, Boolean, OperationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty, Object, PropertyMetadata, Boolean, Boolean, OperationType, Boolean)
at System.Windows.DependencyObject.SetValue(DependencyProperty, Object)
at Xceed.Wpf.DataGrid.DataRow.SetDataContext(Object)
at Xceed.Wpf.DataGrid.Row.PrepareContainer(DataGridContext, Object)
at Xceed.Wpf.DataGrid.DataRow.PrepareContainer(DataGridContext, Object)
at Xceed.Wpf.DataGrid.Row.Xceed.Wpf.DataGrid.IDataGridItemContainer.PrepareContainer(DataGridContext, Object)
at Xceed.Wpf.DataGrid.DataGridControl.PrepareContainerForItemOverride(DependencyObject, Object)
at Xceed.Wpf.DataGrid.DataGridControl.PrepareItemContainer(DependencyObject, Object)
at Xceed.Wpf.DataGrid.Views.TableViewItemsHost.PrepareContainer(UIElement)
at Xceed.Wpf.DataGrid.Views.TableViewItemsHost.GenerateContainer(ICustomItemContainerGenerator, Int32, Boolean)
at Xceed.Wpf.DataGrid.Views.PageGenerator.CreateContainer(Int32)
at Xceed.Wpf.DataGrid.Views.TopBottomPageGenerator.GenerateContainers(Int32, Int32, Double, Double, Boolean)
at Xceed.Wpf.DataGrid.Views.PageGenerator.Generate(IEnumerable`1, TableViewPage)
at Xceed.Wpf.DataGrid.Views.TableViewItemsHost.GeneratePage(PageGenerator)
at Xceed.Wpf.DataGrid.Views.TableViewItemsHost.GeneratePage(TableViewStartPageInfo, Double, Boolean)
at Xceed.Wpf.DataGrid.Views.TableViewItemsHost.GeneratePageAndUpdateIScrollInfoValues(Size, Boolean)
at Xceed.Wpf.DataGrid.Views.TableViewItemsHost.GeneratePageAndUpdateIScrollInfoValues()
at Xceed.Wpf.DataGrid.Views.TableViewItemsHost.InvalidateLayoutFromScrollingHelper()
at Xceed.Wpf.DataGrid.Views.TableViewItemsHost.ScrollToVerticalOffset(Double)
at Xceed.Wpf.DataGrid.Views.TableViewItemsHost.System.Windows.Controls.Primitives.IScrollInfo.SetVerticalOffset(Double)
at System.Windows.Controls.ScrollViewer.ExecuteNextCommand()
at System.Windows.Controls.ScrollViewer.OnLayoutUpdated(Object, EventArgs)
at System.Windows.ContextLayoutManager.fireLayoutUpdateEvent()
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object)
at System.Windows.Media.InvokeOnRenderCallback.DoWork()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate, Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object, Delegate, Object, Int32, Delegate)
Posted: β2024-08-11 05:15 PM
@SchneiderMatt I suspect that one of the alarm or event entries is corrupted. You can try to login with Webstation and acknowledge all of the alarms.
Posted: β2024-08-14 05:50 PM
Thanks Craig, that would make sense. I'll give it a go later. ππ€
Posted: β2024-09-26 09:11 PM
Craig's idea works well, but I'd love to track down this recurring issue. I've had a read of everything that I can find about alarms in EBO, but cannot find anything on locating & eradicating corrupted alarms. Can anyone tell me where to find the info, please, or shoot me the documentation?
