Send InviteCancel
Hello community! I have some questions about integrating some IE104 tags into the driver sheet in EcoStruxure Machine SCADA Expert!
I want to share some tags I created in EcoStruxure Control Expert through the NOR2200H communication module using an M580. I'm going to share some tags as a server to an HMI display, using the IE104 protocol. This data is already created in the PLC. I need to associate these variables in EcoStruxure Machine SCADA Expert, where I have some questions about integrating them.
1. Is there a way to export the IE104 variables I created in Control Expert and anchor them to EcoStruxure Machine SCADA Expert, using a CSV file?
2. Since I have the tags from the PLC, these tags are associated with the same device and its respective ASDU, and each tag has different data formats (M_ME_A, M_ME_B, and M_ME_C, and C_SE_B commands). How can I associate these tags in the driver sheet if they are all in the same group and only the IOA of each tag varies? The driver guide does not clearly explain how to fill in the Header, Address and <Type>.<Operation>:<Offset>.<Qualifier>:<ConfirmationTimeout> parameters.
This is the driver sheet where I want to make the association.
These are some of the tags, I created them in the NOR2200H communication module in Expert Control.
(I don't do this directly in Modbus protocol because the client's SCADA is IE104, and the HMI to be used must have that protocol.)
