Detach AS from ES
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Detach AS from ES
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
andries_cas-hva
Ensign andries_cas-hva
Ensign
Posted: ‎2019-09-16 05:29 AM . Last Modified: ‎2020-12-02 04:30 AM
5568
Detach AS from ES
I'm trying to detach an AS, but there is no detach option available. What can I do?
Kind regards
Andries
andries_cas-hva
Ensign
Posted: ‎2019-09-17 02:42 AM
In response to CraigEl
Hi @CraigEl ,
Thanks for the reply, but the problem is solved. The AS wasn't correclty restored.
CraigEl
Posted: ‎2019-09-16 08:05 PM . Last Modified: ‎2025-08-12 05:14 AM
5559
Hi @andries_cas-hva
In order to get the correct visibility for your question you should post it in the Ecostruxure Building Operation forum.
You don't mention what version of EBO you are using but from the screenshot it looks like 1.x. Webhelp has the procedure to detach a server.
You will need to login to the AS and then from the Actions menu, point to Advanced and then click Detach server.
andries_cas-hva
Ensign
Hi @CraigEl ,
