Conext SW4024 - Lithium capability ?
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Conext SW4024 - Lithium capability ?
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
7
MikaelKrantz
Kirk MikaelKrantz Kirk
7
Back to Ask the Community
Dave186
Dave186
Cadet
Posted: ‎2024-02-08 03:24 PM
1604
Seems as if I cant find any consumer support so ended up here. So maybe someone can help. I have a Schneider Conext 4024 inverter/charger on an off-grid system currently connected to a generator and a solar combiner box as power sources. Batteries are Rolls 6V set up in series in a 24v system. I want to move to LifePO4 batteries and am looking at 12v / 300 aH ones that I'd set up in series. I need to know if this inverter can manage these batteries and if there are any special requirements I need to look for when shopping for the batteries. thanks in advance.
Kirk
Posted: ‎2024-02-09 08:18 AM
1584
The user manul indicates in chapter 4 Lithium / Custom is an option. You need only review the charging requirements for the cells you intend to use. If cells you're interested in can be supported by the Conext SW4024 you're good to go.
NOTE: Regardless of the main charging system in place a BMS needs to be present.
Dave186
Dave186
Cadet
Posted: ‎2024-02-12 09:28 PM
In response to Teken
Thanks very much..i re-read the section and spoke about optimized algoritisms for lead/agm/etc. I believe I need to input the specific ones for my new batteries in the "custom" fields". The new lithiums will have built in BMS so should be ok.
MisterSandals
Ensign MisterSandals
Ensign
Posted: ‎2024-03-22 04:18 PM
I am currently using VERY conservative charge settings for a 30kWh battery bank.  This would be a good starting point to and gradually increase bulk voltage if you want to put more into your batteries.
If you have specific questions please ask.  There are some minimum unexplained difference between some of the values that you will run into if you start experimenting. Nothing quite like poor documentation!
