Compatibility checks
  • Industrial Automation
  • Compatibility checks
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Eddy_Rox
Crewman Eddy_Rox
Crewman
Posted: ‎2024-04-01 09:53 AM
2351
When I try to download a simple test program to the M580 PLC using Control Expert 15.3 I get the following error.
Impossible to transfer project to PLC due to compatibility checks.  (Compatibility level check failed)
Can't find this error anywhere in any Schneider documents.
Eddy_Rox
Crewman Eddy_Rox
Crewman
Posted: ‎2024-04-03 05:10 AM
Rookie mistake, have to make sure the PLC firmware matches the Program firmware.
Thanks to: Woodison Germain | Schneider Electric | Canada | Technical Support Specialist
Eddy_Rox
Crewman Eddy_Rox
Crewman
