Video: Add a partner to your organization in IT Expert
Administration
How to manage your EcoStruxure IT Expert organization including users, groups, subscriptions, and alarm notifications, and Gateways
Send InviteCancel
Enter the Partner ID. You get this unique ID from your partner. Contact your partner if you don't know the partner ID.
Select your partner to add them to your organization.
When you add a partner to your organization, you will join your partner's organization. Your partner will have read only access to your device data by default.
You can grant your partner Administrator access to your organization and access to API device data on the Administration>Subscriptions tab in IT Expert.
You can revoke partner access to your organization at any time.
