Popup Window Position Display Issue in AVEVA Plant SCADA 2023 R2 Multi-monitors
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Popup Window Position Display Issue in AVEVA Plant SCADA 2023 R2 Multi-monitors
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
sinced
Ensign sinced
Ensign
Posted: ‎2025-07-23 01:49 AM
468
In our current setup using AVEVA Plant SCADA 2023 R2 with dual monitors enabled, we’ve observed that popup windows are opening on a different screen than the one from which they are triggered.
Could you please advise how to configure the system so that popup windows consistently open on the same screen where the command is initiated?
  • Plant SCADA Runtime
olivier_vallee
Commander
Posted: ‎2025-07-23 08:56 PM
Hi @sinced,
Can you let us know what project template you are using? If you are using legacy CSV_Include Multi-monitor features, I'd recommend you convert your project to use modern template, which has simplified the MM setup and functionality.
See this section in the help on Screen Profiles for more details:
https://docs.aveva.com/bundle/plant-scada/page/1095480.html
I believe popups called from a page will inheret the window and coordinate system from that page.
See this section in the help for more details about Window functions that can be called:
https://docs.aveva.com/bundle/plant-scada/page/1193971.html
Kind regards
Olivier
