How to fix CTapi is offline?
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • How to fix CTapi is offline?
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Citect SCADA
AVEVA
AVEVA™ Plant SCADA
Back to AVEVA Plant SCADA Forum
Chonlathit
Chonlathit
Cadet
Posted: ‎2022-02-18 02:29 AM
5
4370
Hi every one. I'm using AVEVA Plant Scada (Citect 8.3) for upgrade Citect 7.0 to my customer. Every thing work fine. (Except slower graphic responding) for a few month. Now I have got some comment from my customer that. "We cannot use a Process analysis anymore". and they send me a picture of error (In attachment). The error was "The search failed with the following error : The CTapi connection is offline." How I fix it? Thankfully.
  • ct
  • ctapi
Replies 5
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2022-06-07 05:03 AM . Last Modified: ‎2025-08-12 05:11 AM
You can also use our to AVEVA Plan SCADA Forum
R.-
Rodrigo G.
Industrial Automation Community manager
phil_azzo_com_a
Lieutenant | EcoXpert Master phil_azzo_com_a Lieutenant | EcoXpert Master
Posted: ‎2022-06-23 08:23 PM
Was there a fix for this? I am getting the same with PSO2020 R2 CU1
Posted: ‎2022-08-31 06:41 AM
3630
hi
did you fix it? i have same problem
thanks
Mahsa
Mahsa
Cadet
Posted: ‎2022-10-11 01:39 AM
In response to Anonymous user
Hi All,
I have the same problem, did you fix it ?
Mahsa
ElFago
Ensign ElFago Ensign
Ensign
Posted: ‎2023-06-07 04:43 AM
Hi all,
Have you found any solution for this issue?
I am experinecing the same problem with PO 2021 CU 3 Hotfix 1.
Best regards,
Andrea
