HOW TO OPEN EXE IN CITECT SCADA 2018 R2?
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • HOW TO OPEN EXE IN CITECT SCADA 2018 R2?
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Citect SCADA
Back to AVEVA Plant SCADA Forum
kishore1march
Lieutenant JG kishore1march
Lieutenant JG
Posted: ‎2021-02-27 01:41 AM
7423
I need to open exe file in Citect Scada 2018 r2. For this i have used function as Exec("filename.exe"). But its not working.
Even the allow exec is kept true for all roles under this project. In addition to that, I made Security -> BlockExe=0 in ini parameter.
Kindly suggest any idea.
Thanks in advance
  • 00. Read me first
kingslim
Lt. Commander kingslim Lt. Commander
Lt. Commander
Posted: ‎2021-02-27 04:16 PM
1
7414
Well, you need to login into Citect as a user under a group that has Allow Exec set to TRUE first.
And ...  I found out something in help file stating that Exec only works on 32 bit system (as below). I was at first thinking maybe it could be the cause. But, it does not seem to be true, or maybe it was just referring to the LNK and PIF files. I am on a 64 buts machine, it runs just fine.
kingslim
Lt. Commander
1
7415
kishore1march
Lieutenant JG
Posted: ‎2021-03-05 06:33 AM
In response to kingslim
Hi kingslim,
It worked well after login.
Many Thanks.
