Connecting M241 with Machine SCADA Expert?
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Connecting M241 with Machine SCADA Expert?
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
Posted: ‎2021-03-30 10:55 AM
2209
Hello
I am having trouble finding the best way to connect a Medicon controller to Machine SCADA Expert.
Since both are Schneider products, it should be right forward.  It was when connecting with a Siemens S7-1200.
Am I missing a driver, or is the best connection with OPC UA?
Best regards
Jesper
  • 05. Networking & Communication
SteveAndjic
Ensign SteveAndjic Ensign
Ensign
Posted: ‎2022-01-11 03:49 PM
Hi
It depends on what version of EME you are using. Anything above V1.2x will require secure connection to the M241 which I believe EMSE cant do yet (not 100% certain) so you wont be able to read the tag data from the M241.
EME V1.1x or SoMachine V4.X you shouldn't have any issues
Using OPC UA is an option but the EMSE must be the client.
If security is not an issue you can use MQTT without TLS. you must use port 1883
Regards
Steve
