CitectSCADA/AVEVA Plant SCADA Online printing
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • CitectSCADA/AVEVA Plant SCADA Online printing
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
Qaiser
Ensign Qaiser
Ensign
Posted: ‎2021-11-15 11:43 PM
1
1710
Hey Members,
“CitectSCADA/AVEVA Plant SCADA Online printing”:
I have VijeoCitect/CitectSCADA background and since version 7.4 and starting with Windows 8 and with new PCs without parallel ports (LPT1:), we start facing problems with online printing on Dot Matrix printers connected to USB ports.
We have made a workaround procedure which consist on the following:
  1. Share the EPSON dot-matrix  printer and map it to   LPT1: using dos command  “net use LPT<n>: \\<PrintServer>\<ShareName> /persistent:yes”
  2. Configure the printer under Citect Devises using LPT1.dos as file name
  3. Then write a Cicode to open alarm que and manage the printing
But this procedure is not stable, and not always working fine, the shared name of the dot matrix printer might by changed and set to default by Windows, etc…
Is there now in the new CitectSCADA/Plant SCADA a native solution to for online printing or still we need to go as per above procedure?
Thank you Best Regards
Qaiser Abbas
Rodrigo_Garcia
Commander Rodrigo_Garcia Commander
Commander
Posted: ‎2021-12-13 05:45 AM
Thanks for sharing
Rodrigo G.
Industrial Automation Community manager
