Citect/SCADA Modbus Driver - where to set a Slave ID number?
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Citect/SCADA Modbus Driver - where to set a Slave ID number?
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
mykelse
mykelse
Cadet
Posted: ‎2024-06-08 12:33 AM . Last Modified: ‎2024-06-08 01:46 AM
1452
I know you can set this somewhere, but unable to find it in the help. I'm sure i've done it many years ago before.
Where can you set a Modbus Slave ID?
I'm not getting any values from a Modbus slave device from Citect.
I get a #Bad status on the displayed tags.
Which parameter of Ports or Boards do we set it?
Anyone know?
Cheers.
  • Plant SCADA Runtime
  • Plant SCADA Studio
olivier_vallee
Commander
Posted: ‎2024-06-10 09:59 PM
Hi @mykelse,
The I/O Device (Unit) Address field is typically where you would define the "Station number" of your Modbus device.
So in Plant SCADA (Citect) Studio, you go to Topology, I/O Device, then Address field.
Hope this helps.
Kind regards
Olivier
olivier_vallee
Commander
Hi @mykelse,
Hope this helps.
Kind regards
Olivier
mykelse
mykelse
Cadet
Posted: ‎2024-06-12 10:12 PM
Thanks, that worked.
Cheers.
